I would try swapping the hot and cold hoses at the washer.
If it only fills on the cold setting (with hot water), you aren't getting cold water to the washer for some reason—plugged hose, shut off valve, etc.
If it only fills on the hot setting (with cold water), something in the washer isn't working, probably the cold water fill solenoid valve or its connections or control circuitry.
If something else happens, maybe the washer is too clever for its own good and has some sort of a thermostatic temperature setting system that mixes the water to a more or less precise temperature, and I would in that case probably break down and pay someone who knows more about it to troubleshoot. Most all American washers just select cold/warm/hot by turning on one or both of the incoming water taps, though, and don't actually sense and control the temperature.
