Our ignition cylenoid just clicks and stops. Nothing turns over. Lights work, generator works. Just doesn't start. What's going on? Is there a way test the cylenoid without replacing? Help.
If it clicks the coil should be good. You should be able to read same voltage on the large contacts when a helper energizes it. You could use a single jumper cable between the two large posts. This should turn engine over. However it could have a Bendix type drive on the starter.
