Two_Jayhawks's avatar
Two_Jayhawks
Starter Solenoide
Reading another post reminded me I have an issue to fix and I will welcome all suggestions. We recently arrived at our destination Cherry Hill in College Park MD and backed into our spot. A couple days later I advanced the key to adjust jacks and basically nothing happened. We essentially made it 1200 miles with many stops/starts and it actually quit after we made it. Anyhow GS sent out a tech and he did exactly what Brett Wolfe described in another post on this topic. He had a solenoid on his truck and we were fixed in minutes. The solenoid he had on his truck was used so I sourced a new one from NAPA to have on hand before we left for home. We made it home with no issues. Went to take it out last weekend and same story as in MD. I brought in my local tech and he installed the new part. We nixed going anywhere in favor of letting him check more into it. Solenoide got quite hot to the touch with key in advanced position. We realize now that something is making the solenoid fail. Any suggestions that might save us some time would be appreciated.
  • Hi OnaQuest,
    It is for the engine starter--it need not be continuous duty?
  • A good 14 volt solenoid might be the answer. However, to make use of the current solenoid, maybe adding a large diode in the coil path may lower the voltage enough to run the solenoid cooler yet reliably pick and hold.
    It's not he current going through the large contacts that causes the heat, it's the current through the coil.
    Make sure the current solenoid is rated for continuous duty.
