Ivylog wrote:
Only charges the engine batteries if you hold the boost switch down.
No, not true in all cases.
Mine charges both sets, both ways.
AND....the OPs problem likely will be back again.
NOW would be a good time to get a voltmeter AND check to see if there is supposed to be a BIRD device there or not. I had to replace a solenoid to get mine working.
IF....the problem really was that the engine/starter wasn't turning over at all (which he really didn't actually SAY), I agree that the main problem likely was/is a bad connection somewhere in the main chassis battery cables.
