BobandShaz wrote:
carringb wrote:
Ford RVs are NOT aligned from the factory. Your Ford warranty includes the initial dealer alignment. You would get the most benefit from this by loading up the RV ready-for-travel before taking it in for alignment.
Interesting since they are driven from factor to dealer or I thought so
Not normally (other than a basic eyeball alignment), because dealers may install hundreds of pounds of optional equipment which could affect alignment further, and Ford only pays for it once. And since your loading will affect it as well, that's why you should load it up like you are camping when you take it in.
Also, check the tire pressure. Setting the fronts at 80 psi will reduce the contact patch and reduce traction. I believe an E450 at full front axle weight is supposed to be 65 psi.
