bobndot
Sep 24, 2021Explorer III
theoldwizard1 wrote:
Common problem. Take it to a shop that specialize in alignments. You need to have the caster adjusted to a range outside of the factory specs. This WILL NOT increase tire wear.
Ask your shop about the need for a bushing set.
I had to add a ford bushing set in order to properly spec my E450.
2003-2017 Ford E450 Super Duty Alignment Caster / Camber Bushing Set, Ford E450 Super Duty Alignment Caster / Camber Bushing Set, DIY Solutions Alignment Caster / Camber Bushing Set SKU: 5024-07376532 Rear Wheel Drive; Front Steering 03-17 Ford Alignment Caster / Camber Bushing Set. Replacement Alignment Caster / Camber Bushing Set Parts. 2003 2004 2005 2006 2007 2008 2009 2010 2011 2012 2013 2014 2015 2016 2017 03 04 05 06 07 08 09 10 11 12 13 14 15 16 17
