Hank85713
Sep 24, 2021Explorer
Most of the above can be true, however there are things that you need to check first. Yes I own a 12 aspect. Check tire pressures, do not use the 75psi on sidewall or whatever is on door jamb. I run mine at 60-65 for fronts, 70 for rears. Depending on load what airbag pressures do you run? Again mine is 55-70 again depending on load. Have you weighed the rig mine comes in around 13500 we travel light. 1/3 tank water, empty black/grey tanks (all located over and back of rear axle).
When 1st got ours it did wander but I had to experiment with the above settings to get it to stabilize. I have new shocks to install and I got a new steer stabilizer but havent gotten around to putting on since we are not going to travel again this year due to the virus.
There was a road test back around 10-11 on the winnebago and these were also complained about, however I havent been able to find it since I read it years ago.
PM me if you have questions
