jackie's avatar
jackie
Steering Wheel cocked. I fixed it!!
Last year, my wife and two friends took a trip out west in our Monaco Diplomat DP. The Power Steering Head went out in Utah.
She found a truck repair shop that could order a rebuilt unit and install it. She rented a car for the week.
When she finally got home, she said the Coach drove fine, but the steering wheel was now off center a lot. More of an annoyance than anything.
But last Sunday I decided to fix it. I read up on it, and came to the conclusion that the shop that replaced the head should have adjusted the Drag Link. Heck, I could do that.
I took the Coach to my shop, (I own a Machine Shop), and removed the big drag link ball joint from the Pitman Arm. I loosened the clamp that locks the ball joint thread, and tried to screw it in. It would not budge.
I removed the other ball joint from the driver's side steering arm, and removed the whole drag link so I could secure it in a large vice. Even after applying heat and liquid wrench, it still would not turn. I figure the threads was galled.
This is why the shop in Utah did not adjust the length of link.
Rather than just putting it back together, I decided to fix it by making the drag link adjustable in place.
I took a piece of 4140 steel bar stock, cut it about 7 1/2 inches long, and threaded one end for 1 1/4 12 TPI right hand, and the other end for 1 1/4 12 TPI left hand thread. I also had to make two jam nuts.
I then cut a 4 inch section out of the drag link at a appropriate spot. I drilled and tapped each end with the same 1 1/4 12 TPI, one left hand, one right.
I then assembled the drag link with the "turnbuckle" in place, and remounted the link from the pitman arm to the steering arm. I shortened it about what I thought it needed.
Did a test drive, I had to adjust it a tad more, and now the steering wheel is dead straight when going down the freeway.
I would post a picture of the fix, but I see there is no provision, such as a "manage attachments", for doing such.
By the way. I am 72 years old, and getting to old to be climbing around under a motor home. But my wife is happy.
  • jackie wrote:
    I would never do this for anyone else. I consider it a viable, and completely safe fix, but for my use only.
    I agree, it is likely safe. Viable, not sure. The problem was installed at the same time as a part. Most of my life, that was a indication of a mistake in the installation, or less likely, the part.
    Are you sure you did not change the toe-in?
  • Ivylog's avatar
    Ivylog
    Explorer III
    Guess you should have searched a little more as all that’s necessary to center is to remove the steering wheel shaft from the U joint at the base of the steering column (inside the MH)...takes all of 6-8 minutes. It’s a 10mm bolt holding the shaft in.
  • JRscooby wrote:
    On a RV you will never have a issue. But a truck, that found on a roadside safety check the vehicle would be impounded, not allowed to move until replaced.
    My primary hobby is Benchrest Shooting. I shoot NBRSA Competition, both Score and Group. Since I own a machine shop, I am able to build my own Rifles that I use in Matches.
    While I get inquiries all of the time, I cannot build Rifles for other shooters, including my friends.
    Far too much liability.
  • On a RV you will never have a issue. But a truck, that found on a roadside safety check the vehicle would be impounded, not allowed to move until replaced.
  • My old IPad does not contain the 11 update, so the App won't load. I have a new IPad at home, it might.
  • Use this app provided by member 1492. Upload the photo, copy the link and paste it into your post.
  • zigzagrv wrote:
    Very ingenious fix! Sounds like something I might have done when I was 72. ;)
    I would love to post a picture, any idea how to on this site?
  • Very ingenious fix! Sounds like something I might have done when I was 72. ;)
