Jetwake
Sep 06, 2013Explorer
What you will more than likely find once you get the step up, the end cap on the motor has come apart. It's held on with 4 machine cap screws and those strip out, causiing the gears to disengage. Take the motor out remove the screws, if any are left attached, drill all the way through where the screws screw in and replace them with bolts and nuts. The motor will be better than new and last much longer....
38,769 PostsLatest Activity: Apr 03, 2026
