klutchdust
Jul 09, 2020Explorer II
ferndaleflyer wrote:
Pardon me for intruding on your post. Mine is working fine but the warning light on the dash don't go out. Step works fine and the light underneath goes out but the dash warning light stays on. Your situation can be cured with a new motor assembly that is about $40 from Auto Zone
I changed out the motor on BIL's Monaco and used a power window motor from an older Ford. Don't remember which one it was though. The motor works fine. I watched two videos and saw the gear assemblies in question. IF the larger of the two gears is the one that failed it makes sense that turning it 180* and using the newer side would solve the issue. The coach is a 2009. If the gears lasted that long they may go another 10 years. It's a simple fix and not an issue for me to try.
Mine does not have a warning light however if it did my first choice would be to check the electrical connections at and near the step. Unplug and plug back in or look for a wire loose. If the step has a ground wire check that.
