- GundogExplorer IIMine has some 12 volt fuses where the 120 volt breakers are located. Find your electric panel and see if there are some fuses there.
- Woodchuk103ExplorerOk thanks I'll have to look in there!
- AvaExplorerMy rig has fuses for chassis related electric units, such as the steps, in the control panel that houses the battery shut off solenoids,within my battery compartment.
- midnightsadieExplorer IItime to start following wires ,I hate that. when I add wires ,I put a tag on it telling where the fuse is. and what its for.
- Woodchuk103ExplorerSomebody before me has removed screen door and I didn’t see a light also they had put a toggle switch on it . It stopped working so I tried to get it to work by using a hot wire from my cabin switch and it sparked now dosnt work and no power to cabin switch I’m lost thanks ! I have power to cabin fuses in back and all things work but my switch for cabin has no power and will not shut off power to fuse box if that makes any sense ?
- Turn on the engine, open and close the door. IF the underside round amber step light goes on and off, your fuse is good. Doug
