valhalla360
Aug 26, 2014Navigator
Without getting crazy expensive, truck campers are the off road RV of choice.
- Find a truck camper group (or just an experienced guy) and have them check to make sure your tie downs are set up properly. You can't tie them down so tightly that you eliminate all movement but if they are too loose that can also be bad.
- Look into a front mounted hitch to mount a portable generator. That will give you power away from developed camp grounds. Search the forum on generator sizing so you understand what size to get to support running the air/con.
38,778 PostsLatest Activity: Jun 04, 2026
