D_E_Bishop
Sep 08, 2018Explorer
Of course that helps, google what you gave us and you will see that it has been discontinued, that's not a bad thing, it's 720p set with two HDMI inputs and one F type connector for antenna in.
It will not play BluRay discs but it will play DVD discs. There is every thing else you need to know already given to you by other members of the forums.
First I would take the set in the house and try it or bring a DVD player to it and try that. That will tell you if the set is working or not. From there on your on your own but with the info given you, you'll solve any problems you think you have.
You can get a typical hook up diagram or two or three thousand, just google it.
38,763 PostsLatest Activity: Dec 05, 2025
