FIRE_UP
Sep 10, 2018Explorer
3 dog nights wrote:
Receiver on coach is @ 26", Connector pins on Toad @ 16". Am being told I need an 8" drop down receiver. Is it safe to use? Seems like a lot of pressure is going to be on those welds, especially in a turn.
Based on your statement, you have a 10" difference between the centerline height of the receiver and the centerline height of the toads connection points, correct? If so, to get your tow bar completely flat and level, you'll need a 10" drop extension. But, most towbar manufactures are ok with a 4" swing. That is, two inches up or down from dead level.
In that case, an 8" drop extension would work just fine. Yes, there's gonna be some strain on it and any welds associated with it. No big deal. Especially if you purchase a commercial one. Those boys know what kind of stress is going to be applied so, the proper procedures are used for the welding process. You'll be just fine. Just make sure you have enough clearance for dips and things so you won't scrape it (the 8" drop extension).
Scott
38,769 PostsLatest Activity: Apr 24, 2002
