rgatijnet1
Sep 11, 2018Explorer III
3 dog nights wrote:
Thinking of attaching a piece of chain or something, paint it a bright color, then letting it hang just below the drop hitch. Maybe an inch or two. If I'm going to drag, the chain would be playing out before the hitch touches. I would see this in the rear monitor. Still a thought in process, so bear with me.
OK, lets assume that you see in your monitor that the chain indicates that you are going to drag....WHAT THEN?????
I doubt if you will be able to back up with your toad to avoid an area where you might drag. Do you disconnect the toad and remove the drop hitch so that your coach can pass over the area without dragging?
After that, do you then pull the coach over, drive the toad up to the coach, reinstall the drop hitch, reconnect everything, and then continue your journey, 30 minutes or so later and with a few people in line behind you?
38,769 PostsLatest Activity: Apr 24, 2002
