Bamaman's avatar
Bamaman
Storage Question
In between trips, do you store you motorhome on the leveling jacks on just let it sit on the tires? Why or why not?
What about getting the wheels off the ground via the leveling jacks to keep from getting flat spots on the tires? I know they will round out after a few miles but just asking.
Thanks in advance!
  • Jacks down, tires on the ground. Just like at any campsite. Too much slope on the driveway to run fridge without leveling. Slides out, hooked up to water and electric.
  • I put the legs down and level it just like when I'm camped somewhere. I didn't once and a tire had a slow leak (loose valve extender). The tire went flat and popped the bead. If I'd had the legs down I wouldn't have needed to spend $225 for a service call!
  • wolfe10 wrote:
    I am assuming this is a trailer and the jacks are mechanical. If so, yes, take most of the weight off the tires.
    The OP asked about storing a motorhome.
  • I am assuming this is a trailer and the jacks are mechanical. If so, yes, take most of the weight off the tires.
  • I leave the tires on the ground. I figure the chances of a hydraulic line rupturing are greater if they're under pressure all the time.
