donfrump
Dec 17, 2015Explorer
dougrainer wrote:
Can it possibly be your Aqua Hot water heater/Furnace system? They have circulation motors that run coolant thru the floor heat radiators AND thru the engine block if you have that switch turned on. The floor radiators also have small blower motors to blow the hot air out. Doug
aqua hot runs engine coolant from block thru boiler and a totally separate boiler fluid from boiler through Motorhome heat exchangers
2 separate systems by different pumps and switches
