Rbertalotto's avatar
Rbertalotto
Strange RV wiring.....
Here's one for you...While doing some solar work on my friends brand new $50,000 Winnebago trailer I found these three Auto Reset circuit breakers mounted on the side of the frame rail. Can't believe how bad this is. 24" of #4 wire with no protection at the battery. Two 30a CBs tied together with a piece of copper strap that feed through another 30a CB. One wire (Green) that is connected to CB2 input, but because CB2 gets its feed through CB1, it is protected by CB1...(I labeled "no protection", but it is protected by CB1).....I have no idea what any of the three wires connected to CB2 or CB3 are feeding. Spent hours trying to figure it out. There is no current flowing through them with a clamp amp meter no matter what we turn on in the camper. All these wires are only 12g.......Comments?
  • Rbertalotto wrote:
    "and #4 copper will carry a lot of amperage. "
    EXACTLY, and when it chaffs on the chassis what is going to give...the #4 wire? The battery? I want a fuse right at the battery......No other way!
    #4 thhn has a lot of insulation, It would take a long time to rub through if ever. And most wiring I have seen running under an RV is in a loom which gives it even more protection.
  • The one with "0 protect" is probably the feed to the trailer emergency breakaway switch. This should NOT be fused.
  • "and #4 copper will carry a lot of amperage. "
  • Can we get a picture? It's unclear what is intended as wires and what are leader lines pointing things out.
  • If I am reading this correctly, having no protection from the battery to the first circuit breaker with 2 ft of #4 wire is no big deal. The wire coming from the pole into your home has no protection either. It's a short run and #4 copper will carry a lot of amperage. As to your other questions,I don't know.
  • Can you post an actual photo of those breakers and wiring?
    And edit the picture above to a width of 450?
  • For their motorhomes, they provide wiring diagrams and wire identification charts. According to that, CB is for IGNITION SWITCH START SOURCE. Which doesn't make sense in a trailer. Not sure if there is connection between trailer and motorhome wiring identification. They all have some type of code on them. Here is the web site: https://www.winnebago.com/Files/Files/Winnebago/Resources/Diagram/Wiring.htm Also, their support line will get the information for you sometimes.
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
