dougrainer
Dec 22, 2014Nomad
CA Traveler wrote:MR MAC wrote:Bad or low voltage batteries can cause strange and unexpected problems.
MH was in driveway about a wk., went in and turned on bat switch to on position, so as to turn on some lights, after a few seconds main slide went out, tried to bring in, came in half way and went out again. Did this a couple of times, then wouldent move at all. MH was not plugged in, ran gen. charged up batt. Now all is well-strange? Don't know if this could happen when driving, or if I had lock bars in place. Think I'm calling dealer. (2014 Coachmen Pursut)
Have your batteries load checked and then keep them charged. The batteries should also be charging when you are driving. If you can't plug in then use or install a full battery disconnect switch.
It's also possible that you have a defective part (circuit board, relay or???) or even a poor design that doesn't work well with low voltage.
Lets take your premise(low voltage). If so, WHERE would the current come from to extend the room fully? Sorry, bad batteries/low voltage will not cause such a problem. Circuit Board/relay or switch as you stated is the probable cause, but it should still not happen at all. Doug
38,769 PostsLatest Activity: Mar 31, 2026
