- sljkansasExplorer" but how do you get mixed material in a hole without making a mess?"
Tape off the area around the hole with painters tape before you apply the JB Weld. - IAMICHABODExplorer II
Grillmeister wrote:
ctpres wrote:
Off to nearest HD and here in NW WA that may take a few days.
JB Weld products are also available here.
I even found it at Walmart! - RckyMtnViaExplorerI have used the tooth pick with Loctite in areas where I never want the screw to come loose again.
- GrillmeisterExplorer
- ctpresExplorerOff to nearest HD and here in NW WA that may take a few days.
ctpres wrote:
JB weld will solve my problem - but how do you get mixed material in a hole without making a mess? Need to fix a screw hole in fiberglass with wood underneath.
I use "JB Stick" for vertical applications Here
It is the consistency of clay. - ctpresExplorerJB weld will solve my problem - but how do you get mixed material in a hole without making a mess? Need to fix a screw hole in fiberglass with wood underneath.
- mvpmichExplorerThe wood match approach works but doesn't proved an extremely strong condition. There's a product available that looks like small triangular pieces of corrugated metal that are inserted into the hole. The rough edges bind the the surface via the pressure from the screw. Sorry that I don't know the name of the product as I no longer have the packaging.
- powderman426ExplorerIf there is a chance of water entry, I would use Lab metal. It comes in a can like bondo, but when this stuff hardens it is machinable like metal. Its available at Fastenall.
38,760 PostsLatest Activity: Nov 14, 2025
