n7bsn
Jun 07, 2013Explorer
Is the motor turning? If not, is there a separate fuse for the slide motor? (both my current and last rig had this). If so, check that fuse.
If it is turning, the odds are good that a shear-pin, connecting the motor to the drive, has sheared.
Can you hand-crank it out? (you might have to hand-crank it back in too, so only a bit, then check to see if you can crank it back)
38,782 PostsLatest Activity: Sep 02, 2026
