Community Alumni
Feb 13, 2017Not applicable
You said you were in the evacuation zone if that is true why are you there? Also If I was a tow operator I would not got into an evacuation zone unless I was directed by emergency services to save life and property.
Now that all that is said I watched a TV show "Highway Through Hell" and they in one situation used airbags to lift a heavy trailer something like that may work and not mess up things or sink.
I am now to your south and every thing here is very wet and muddy, water is coming up through the ground in a spring action and causing issues if one strays off the hard path. If the same there you will need a very large base for the jack if you try to jack it up. Remember heavy duty jack stands if you do go under the MH.
Please do be Safe
JimR
Please do be Safe
JimR
