On the way home from the 500 stopped to see dw's parents. Backed into a spot and got stuck in the yard. I'm calling coach net Friday when we are ready to leave. My question is where are the correct p...
On the frame for sure BUT... more importantly the hooker should use a block pulley at ground level so that there is no vertical pull. The cable should be a pretty straight pull at ground level. A good hooker will know this. That's the only way to get big trucks moved. If it's a small wrecker he may not have that capability. Tell them to send a bigger hook. :) :)
