whizbang's avatar
whizbang
Explorer II
Oct 11, 2018
Sub-freezing Weather UPDATE --- We froze the pipes!
Per everybody's suggestions, we started the empty holding tanks with a couple gallons of anti-freeze, then waited until they were real full before dumping. It worked great!
The problem was the bathroom pipes.
The walls, floors, and cabinets with the bathroom pipes are in the back rear of the RV. They are completely sealed and unheated. There is a heat duct in the bathroom, but zero heat in the plumbing enclosure.
We dodged around western Montana and managed to camp no colder than 30 degrees F. We also had the good sense to unplug the electric space heater and run the furnace so the duct put out heat. No help.
The toilet line froze. The bathroom sink had almost froze thru when I turned it on and cleared it with warm water. I suspect the shower froze (but when we got around to showering, it was warm enough that water ran. However, the shower P-trap froze and it wasn't until my wife shower filled the pan with warm water that the p trap thawed and flowed.
Our leak appears to be the screw on hose connection for fresh water. It was on its last legs and I have a replacement part on hand at home. I think the cold weather pushed the spring loaded seal to its end of life.
I am still going to install holding tank heaters and blankets.
I am also going to install a new supply connection and shower faucet, and, when I do so, wrap the lines with pipe insulation as much possible.
Additionally, I am going to "Y" one of the rear furnace ducts and route it into the plumbing enclosure to warm the pipes.
My cold weather plumbing problem wasn't where I expected it to be. Go figure.
  • I,m sorry to hear that things froze at that temp.
    I once did the same as ron.dittmer suggests and added a 12v computer fan at one duct, it allowed the space fill with warm cabin air which vented out the opposite end.
    I also re-routed water lines off the outside exterior wall (so they don't touch the wall) and was able to wrap them in foam tubes.
  • Ron makes a good point. Just having warm air isn't enough. There has to be some place for it to flow.
  • If applicable, consider installing pairs of little 4" round louvers to allow air to circulate between walls or compartments that have concern of freezing so that warm air gets into where the pipes are located. Place them far apart to get flow-through action.
    Something like this.....
    Some are sold with screens so you don't let in insects.
    You might even find some with closures.
  • there wasn't cabinet doors that could be open to the plumbing. Also are you saying no colder than 30 degrees and things froze. I find that hard to believe:(
  • Sorry about the freeze up.
    One reason the window fans work is that warm cabin air is circulated before the cavity gets too cold.
    I agree adding a Y is a good plan.
