time2roll
Jun 08, 2020Nomad
The test is done with utility power or generator power?
Have you found why the tv quit?
50 amp or 30 amp RV?
Have you measured the voltage?
And no I don't believe the Hot & Neutral wires suddenly swapped terminals. I suspect floating neutral of a generator may cause a false reading or you have a bad neutral in a 50a setup.
