Radio Power Switch
The Radio Power switch lets you connect the
dash radio to the coach batteries with the ignition
switch turned off for listening while parked. This
prevents accidental draining of the chassis
battery with prolonged use of the radio.
NOTE The HouseCoach Battery Disconnect
switch must be ON while listening to the
dash radio, as the audio relay is powered
by house batteries. If the HouseCoach
Battery Disconnect switch is OFF, the
speakers will not emit sound.
Radio Power Switch
(Located on lower dash area)
Press HOUSE to listen to the radio while
parked without the ignition key on.
Press ENGINE (ENG) to listen while driving
