- gatorcqExplorerWith the power of hydraulics - you will never know if he original bell crank is bad. I always thought mine was good, until it was removed and I played with it. Hard to turn at first, after a week it froze up.
I changed my when I found he online price I was looking for. In the area, installed, received the online price for the bell crank.
FL XC chassis - bmwbobExplorer
fcooper wrote:
bmwbob:
First of all, I have not changed the bell crank, so I can not comment on that.
Your rig (from your profile = 1999 Newmar Dutch Star 38' diesel pusher) will be on basically the same chassis as my motorhome. I've chased the same problems, and have solved them without replacing the bellcrank. Mine seemed to have excessive steering play.
Yes, the Koni FSD helped the ride a lot. After a good alignment, I still had the problem you described. After checking for worn components, I determined the loose feeling was from the steering gear box. Luckily, it is adjustable. After minor adjustment, it tracks much better.
I could still feel the tires following the ruts in the road (very minor problem) and installing a Steer Safe cured that problem.
Adjusting the steering gear box is a controversial subject. Some authorities claim you must remove the box and make adjustments off the rig to get it right. Many shops refuse to adjust the steering gear box. There are a number of Freightliner chassis owners that have realized improvements by adjusting the excess slop out of the gear box without removing the gear box. The adjustment is on the side of the gearbox, with a hole in the frame member provided to allow access to it. Make very minor changes and test drive. It's better to be a little loose than too tight.
There is additional info about this on the Freightliner Chassis Owners Group on IRV2.
I've had the Steer Safe damper on the rig for quite some time since I originally thought that my wife would be sharing the driving (NOT!).
I can recall adjusting the steering gearbox wear adjuster on older cars I owned many years ago. The shop that put my Koni shocks on is honest and competent. I think I'll consult with their wrench about doing the adjustment since there seems to be such a difference of opinion about it here.
Thanks for all the tips! This is a GREAT place for avoiding reinventing round discs with holes in the middle! :-)
Bob
Fred - wolfe10ExplorerThe life of the OE Freightliner bell crank is largely determined by the "care and feeding" it has received.
It has BUSHINGS, not bearings, so is sensitive to having clean grease in it all the time.
Easy to determine if it is worn. With engine off, have someone turn the steering wheel back and forth through left/right arcs. Watch the drag link coming from steering box to bell crank, and then the link from bell crank to the left steering knuckle. Any up/down or angular play in the bell crank means you need to do something.
Indeed, the Henderson bell crank with BALL BEARINGS is a big improvement over the OE design.
And, while under there, check the sway bar END LINK BUSHINGS for wear-- there are 8 of them and a high failure rate item. Easy to replace-- go with polyurethane replacements. - bmwbobExplorer
RayChez wrote:
Are you sure it is the bell crank and not the tires?
The Michelin tires are two years old with about 6K miles and no signs of uneven wear.
Bob - fcooperExplorer IIbmwbob:
Fred - smlrangerExplorerHenderson's does have them for the XC because I put one on my previous coach. I would make sure all the other steering components are OK before spending the money for the bell crank. In my case, my OEM bell crank was sticking and the Supersteer unit is bearing smooth. It improved tracking in my coach with the XC chassis.
- Ranger_SmithExplorer
bmwbob wrote:
Does anyone have any experience with these units?
After the marked improvement from the Koni FSD shocks, I looking now to eliminate the constant back and forth movement of the steering wheel needed to keep the rig on a straight track.
And, do I need to have them put on both sides of the rig?
Bob
Might want to check the play in the steering box. I have no wander with ours what so ever. It is a pleasure to drive and don't need to keep working the wheel. - RayChezExplorerAre you sure it is the bell crank and not the tires?
- bmwbobExplorer
SacsTC wrote:
I don't think that Henderson's makes a Bellcrank for Freightliner chassis. They are for P-30 and P-32 motorhomes.
I'm looking at their catalog right now.
The part number for the Freightliner XC chassis is SS100.
Bob
38,782 PostsLatest Activity: Sep 02, 2026
