- OFDPOSExplorer
S1njin wrote:
IAMICHABOD wrote:
Front Sway : If you don't have levelers then upgrade the puny undersized stock Anti Sway Bar with a Hellwig.
What do levelers have to do with upgrading the front sway bar?
Think you got him mixed up with me.
What does levelers have to do with upgrading the puny front "Anti" sway bar you ask...
Before you have the "Anti" sway bars replaced , stand up in the middle of the MH now rock back and forth ..
Then do the same thing again once the "Anti" sway bars have been swapped out..
You won't "sway" back and forth as much..
Your better half won't scold you as shes putting on make-up etc while your moving around in the MH..
I'm not a very big person 5'11 218lbs and before I replaced the "Anti" sway bars just stepping on the step going into the MH it would lean/sway a little bit.
So that's one big reason why I said "If you don't have levelers then upgrade the puny undersized stock "Anti" Sway Bar with a Hellwig"
I ordered both F&R Hellwigs from the same place you did, I received them with 5 business days..
Its spring time and they tell you it will take 2-3 weeks and all 3 times I ordered them they showed up within 5 business days.
Oh and when the Brown truck shows up with them , the boxes will be ripped open. At least all 3 times I ordered them the boxes were ripped open.. All parts were in sealed plastic bags or little boxes taped inside.
If your home when the deliver , might want to do a quick look to make sure all the nuts, bolts , links etc are there before signing for them. - HarvardExplorer
S1njin wrote:
I ordered both front and rear bars from SDTruckspings.com. Apparently Hellwig is a build to order type place so now I wait awhile. Got my alignment scheduled with a truck shop the day after we get back from our shakedown trip.
Re: Your shake down trip, if it wanders and is hard to keep between the lines it is because of too little caster.
For example.... - S1njinExplorerI ordered both front and rear bars from SDTruckspings.com. Apparently Hellwig is a build to order type place so now I wait awhile. Got my alignment scheduled with a truck shop the day after we get back from our shakedown trip.
- S1njinExplorer
What do levelers have to do with upgrading the front sway bar? - FunTwoDrvExplorerEveryone's advice seems in-line. I would go with weighing it and setting tire pressures accordingly along with an alignment with a lot of positive caster dialed in and then go drive it and see how it feels.
We have a 2015 GM chassis so, our experience may be quite different. I made a few changes (Bilsteins, alignment, air bags, Sumos) in an effort to make the handling "predictable".
Gary - S1njinExplorer
kerrlakeRoo wrote:
I've been curious on something like this too. Has anybody tried driving the Jayco Greyhawks with their J-Ride compared to the other units standard configuration. Jay ride plus is on the Greyhawk line.
J-Ride plus adds
Bilstein shocks,
Helwig helper springs
Front and rear stabilizer bars
rubber isolation mounts
It would be nice to be able to talk to a delivery driver with time in several brands to get a comparative view.
I had a Jayco Greyhawk with this on it. 1 Finger driving down I95 if it wasn’t windy. I suppose I’m spoiled now ! - HarvardExplorerPOPULAR MECHANICS MAY 1973:
START QUOTE:
If too little caster exists, the car will wander and weave,
thus necessitating constant corrections in steering.
END QUOTE:
There are at least two ways to increase the effective
runtime caster (see Self Aligning Torque):
1. Decrease the tire inflation pressure to the required
minimum for load (to increase Pneumatic Trail), and or
2. Increase the caster angle during an alignment
(to increase caster trail).
If you find an improvement in reducing the tire pressure
you will be amazed what it is to add +2 degrees of caster. IMO. - Hank85713ExplorerI had some initial issues with the 2012 winnebago aspect. Looked at alignments, new stabilizer all the stuff you have listed for the most part. Found that having the tires at a decent pressure, not the max helped greatly as did increasing the air in the rear airbags to a minimum of 55-60 PSI. You do have airbags dont you? Anyhow that took all the fighting out of the system, still may have some push/pull from passing big rigs but that is typical of all slab sided vehicles. Bow wave get everyone all the time just depends on your set up as to how much effect it has. rv weighs in at around 13K 1/2 of all liquids, black grey tanks empty. We dont carry much as there is little room for extra stuff anyplace on the rig. Small outside storage bins and not much inside either.
if you have airbags play with them to find sweet spot, same with tire pressures. I run 60 in front 65 in rears like I said we dont carry much load do tow a Hyundai but it really does not add to the coach weight just draw weight. - OFDPOSExplorerThank you IAMICHABOD !!
- IAMICHABODExplorer III
OFDPOS wrote:
Contrary to what others post about NOT getting pushed by a semi PASSING them once they did an alignment or even all the above is lying to you...
It may help some to a lot , but you are still going to get pushed by a large SUV on up to a semi passing you.
Have read where people say they don't get pushed by a semi only to say they don't get pushed by a semi while PASSING THEM , big difference in passing and being passed... You still are going to get pushed ...
Sorry don't know how to do the click here link, but this little video shows the effect of what happens when passed by a semi in layman's terms...
http://blogs.discovermagazine.com/d-brief/2017/08/28/vaping-next-to-truck/#.WsFU8YjwaUk
I agree and Made A CLICKY For ya :B
38,766 PostsLatest Activity: Jan 10, 2026
