jd_hExplorerMay 09, 2018sway bar bushingsNeed new sway bar bushings on Ford F53 chassis, in Colorado Springs. Any repair places recommended? Than you in advance, J.D.
ThomBolesExplorerMay 10, 2018I too went with the bushings above. The rubber bushings had mostly melted away. It was an easy DIY change-out in the driveway. <-- ***If you have the tools and your health allows you to do it.
Related ContentSway Bar Bushing LubeSway BarsSway bar issuesAnti-Sway Bar BushingF53 Rear Sway Bar Bushings: Wrong Size
