timmac's avatar
timmac
Sway Bar Upgrade Question on F-53
I have done the Cheap Handling Fix and it works great but was inspecting under motorhome and found my sway bar rubber bushings are getting wore out.
So was wondering if I should upgrade the front and rear sway bar or just the bushings with Road Master Polyurethane Bushing Kit for Ford F-53, has anyone upgraded the sway bars as well and was the ride even better or just stay with the cheap and do the bushings.
2008 Bounder F-53.
:C
  • timmac wrote:
    Thanks for the replies, might just go with the cheap and just replace the rubber ones with polyurethane bushing instead of trying out after market sway bars, the CHF did wonders just by itself, guess no need to spend hundreds of dollars for new sway bars.
    I bought these as well, hardest part of the job was getting the old goohy mess of the old ones off.
