FarmerBob's avatar
FarmerBob
Switch at the door
I have a 2006 National 29'. On the left when you go in the door there is a switch box with compartment light switch, step, porch, battery disconnect buttons. The battery disconnect and step switch do not work. I wanted to disconnect the house batteries for the winter but I cannot do that with the door closed, so that means the steps will be stuck in the out position. Anyone know how I can fix this? Not sure how to post a picture of this switch box.
Thanks, Bob
  • On mine the stairs are activated when the magnet on the screen door is opened. When I work on the batteries, under the entry stairs, I tape a magnet over the connector so they will retract. That might work for you too.
    Thanks, Bob
    Possible to just get to the Battery and disconnect the ground - usually the battery is located outside.
    (Or is in inside under the steps?)
    Just a thought,
  • no, batteries are fine. Steps work when opening and closing door. The switch to turn off steps and battery disconnect don work.
    Thanks, Bob
    just a thought here but maybe the batterys are dead? both cut off solenoid and steps wont work; try running engine and see if the steps work
