Belgique
Sep 10, 2013Explorer
Table re-cover
The table in the MH is looking bad. The flimsy plastic that was applied at the factory is peeling off around the edges. Anyone had this problem? How did you re-cover the table? Thanks!
Clay L wrote:loulou57 wrote:Clay L wrote:
You can use contact cement to repair it. Although as I understand it manufacturers have to use water based cement but individuals don't.
I use solvent based and it seems to hold much much better. I haven't tried to buy quart cans so don't know if larger amounts are available but tubes are.
You can buy Quart cans at box stores. A 3M product works great, no odor either.
Are you sure that is solvent based? I haven't seen any solvent based with no odor.
It would be nice if quarts of solvent based contact cement are available because I have a project coming up that will need a lot more than what comes in those small tubes.
