Artum_Snowbird
Jul 12, 2016Explorer
On your toad, when you say everything works.. when you put your tail lights on, you should also have front clearance lights. Are they working?
If your brake and turn lights on the back work correctly, but not your clearance lights I would hazard a guess that the feed connection for running lights is not working through the connecting plug.
That positive voltage feeds all four running lights. I would get your jumper cables out, and bring a positive and negative feed to the correct terminals on the toad plug using short bits of wire to make the connection, and test the toad lights that way. If that works, then you do not have power at the motorhome plug.
