fvidania's avatar
fvidania
Tail lights won´t turn on
Hi all,
My tail lights don´t turn on. All other lights are working properly, brakes lights work, turn signal and reverse lights work but tail light.
I tried changing the bulbs even though they look good, and didn´t fix it.
I´m thinking it can be the fuse for this lights, but I don´t know how to recognize it between all the fuses I have.
My motorhome is a 2005 Georgie boy Landau 35ft and the 12V fuses boxes is located besides the steering (according to the owners manual).
Any tips on how to identify the tail lights fuse? changing this will fix the problem? could it be something else?
Thanks
  • bulbs look good.
    markers light dont turn on either.
    I located the fuses and say " See owners manual for info" but it dossnt say anything.
    Photo here:
    http://postimg.org/image/io0lv37lv/
  • And you think that changing the fuse will fix the problem? thanks for the quick response!
  • The fuse block should be labelled T/L or T/light, you might need a light to read it.
