happy-2ExplorerApr 07, 2016tank drainwhen is the best position to drain your tanks?when the rv is on the ground,or when it is on site and level. do the tanks drain slop to the rear.???
fourmatExplorerApr 07, 2016Level is always best but unless you are on a hill they usually drain pretty well
Related ContentGrey water tank won't drain completelyHouse battery drainBlack tank not draining!Fresh water tank drain.Draining hot water tank
