Gary_Explorer IIOct 03, 2016Tape covering joints on outside of MHI have a 2000 Harney Riata. It is made with the bottom half of the coach made first and set on the chassis. Then the top half was made and set on top of the bottom half. There is a joint where they...Show More
Teacher_s_PetExplorerOct 04, 2016I agree with donkeydew, you probably are referring to a vinyl trim insert that covers screw heads.
Related ContentOUTSIDE GROUND COVERING?Ball joint failureNew Outside StairsBall joints?outside storage, to cover or not to cover?
