  • Gorilla tape comes in white, I've bought it at Menards and it sticks well to the outside of the awning. Looks like it's available here
    https://www.walmart.com/ip/Gorilla-Glue-Tape-White-10yd/166045092?wmlspartner=wlpa&selectedSellerId=101007480&adid=22222222228000000000&wl0=&wl1=g&wl2=m&wl3=42423897272&wl4=aud-834279575686:pla-51320962143&wl5=9021498&wl6=&wl7=&wl8=&wl9=pla&wl10=140256681&wl11=online&wl12=166045092&veh=sem&gclid=CjwKCAjw7-P1BRA2EiwAXoPWAxdv8LmWMicR0jFepUCd7YlTUFcYsxRDWAni1a8wHWSehMBY-XauKhoChq4QAvD_BwE
  • The Gorilla tape appears to be the answer. Wish it came in white or silver.
  • Camreal, thanks. I saw Zip system on Amazon. It says "Withstands up to 180 days of direct UV exposure" . I suggest it won't last for more than 1 year. Are you using it to project the awning (when parked) or does it stick to your awning fabric? thanks
    Camreal wrote:
    I used ZIP system tape over 5 yrs ago and it still working great. Its a black rubber tape that once it is on it wont come off and is water proof. Contractors use it for sealing windows. I used it to repair the awning edges at the top. Sun had cracked the material. I use it on both sides of the material . Can be had from
    Amazon for less that $30 for 20 ft roll 3 3/4 in wide.
  • I used ZIP system tape over 5 yrs ago and it still working great. Its a black rubber tape that once it is on it wont come off and is water proof. Contractors use it for sealing windows. I used it to repair the awning edges at the top. Sun had cracked the material. I use it on both sides of the material . Can be had from
  • I assume you are talking about protecting the awning from the sun while is is rolled up.
    There are commercial protectors on Amazon, Ebay, RV stores, etc..
    You can make a DIY protector from plastic rain gutter. Search Youtube for 'RV Awning Protector', there should be several videos available.
    I'm sure the Gorila Tape or maybe a strip of Eternabond will work well if you don't to be installing/removing an awning cover.
