10forty2
Apr 27, 2015Explorer
I did a small set of graphics on the rear of my coach to replace with a custom graphic that I had made. It was a royal pain, but I finally did it without damaging the structure or finish. Best method was a hair dryer and a lot of patience. Solvents made the color on the graphics run and then there was the whole problem of the color staining the surrounding surface of the coach. I did use one of those plastic scrapers to help get the stickers off once they were heated. You will be left with some of the glue and there really isn't any other way to get that off except for a solvent of some sort. I used Goo Gone and lots of elbow grease.
Good luck!
Good luck!
