Mile_High
Oct 20, 2017Explorer
aboeck3 wrote:Al, does it get pumped down the drain, or gravity drains down. I ask, because the toilet is like a big P-trap (no pun intended), and water would at least stay up to the level of the top of the pump unless it is leaking from the pump. There is a check valve before it goes into the 2" PVC routed to your tank, but it should hold water in the bowl even if that was bad.
We are not on city water, just working off fresh tank and water pump. Our Tecna toilet is not holding water, when we try to fill the bowl, the water just goes down the drain. Any suggestions?
