MrWizard
Oct 20, 2017Moderator
dougrainer wrote:
The most common cause of a Tecma not holding water, is, the Tecma tube/vent system is NOT above the lower P trap. If NOT above it will siphon direct into the tank. The Tecma PUMP has nothing to do with it. Doug
yes, but how is this anchored ?
this is a 2017 ? how long has the OP had it, how many miles ?
this tube vent, should not have moved ?
the vent tube for the black tank ? should be firmly anchored in the wall?
is it common for this to move, or this problem associated with new incorrect installs ?
sounds like a 'warranty' problem
the OP needs help, and im learning something new
but only if all the details to the situation are explained
