gutfelt
Oct 20, 2017Explorer
MrWizard wrote:dougrainer wrote:
The most common cause of a Tecma not holding water, is, the Tecma tube/vent system is NOT above the lower P trap. If NOT above it will siphon direct into the tank. The Tecma PUMP has nothing to do with it. Doug
yes, but how is this anchored ?
this is a 2017 ? how long has the OP had it, how many miles ?
this tube vent, should not have moved ?
well I would opine if you read the thing about installation and being fairly new the vent tube was most likely installed at the very minimum height required at best and through usage and movement has slid or shrank down just enough so the water siphons out??? (just a idea)
