glamisorbust
Aug 20, 2014Explorer II
A motorhome on a 2 ton truck chassis(gas motorhomes) handle much differently than DP's. The tires are narrower, suspension is not near as heavy duty as you will find under a DP. Also, none of the gassers have air ride suspension. To get that, you will be buying a diesel. The airbags ride smoother than a leaf spring could ever dream of. Also, the braking is completely different. Air brakes are priceless. If you go drive a DP, you'll want it bad. Just warning you!;)
