From the code:
Sec. 521.081. CLASS A LICENSE. A Class A driver's license authorizes the holder of the license to operate: (1) a vehicle with a gross vehicle weight rating of 26,001 pounds or more; or(2) a combination of vehicles that has a gross combination weight rating of 26,001 pounds or more, if the gross vehicle weight rating of any vehicle or vehicles in tow is more than 10,000 pounds.
Acts 1995, 74th Leg., ch. 165, Sec. 1, eff. Sept. 1, 1995.
Sec. 521.082. CLASS B LICENSE. (a) A Class B driver's license authorizes the holder of the license to operate: (1) a vehicle with a gross vehicle weight rating that is more than 26,000 pounds;(2) a vehicle with a gross vehicle weight rating of 26,000 pounds or more towing: (A) a vehicle, other than a farm trailer, with a gross vehicle weight rating that is not more than 10,000 pounds; or (B) a farm trailer with a gross vehicle weight rating that is not more than 20,000 pounds; and(3) a bus with a seating capacity of 24 passengers or more.(b) For the purposes of Subsection (a)(3), seating capacity is computed in accordance with Section 502.162, except that the operator's seat is included in the computation.
Sec. 521.083. CLASS C LICENSE. A Class C driver's license authorizes the holder of the license to operate: (1) a vehicle or combination of vehicles not described by Section 521.081 or 521.082; and(2) a vehicle with a gross vehicle weight rating of less than 26,001 pounds towing a farm trailer with a gross vehicle weight rating that is not more than 20,000 pounds.
So yes, if you are over 26,000 lbs you need a non-commercial class A or Class B depending on details noted above.
