topflite51
Nov 20, 2015Explorer
Appears that most people have failed reading comprehension or haven't bothered even reading what it says on the sidewall of a 19.5 or 22.5 tire. Don't read what it says on your passenger car tire or light pick up tire and think they are the same, read what it says on a 19.5 or 22.5 tire, THEY ARE DIFFERENT.
If your tires on your MH are actually LT's then the pressure on your sidewall is the max pressure. If your tires on your MH are medium to heavy duty tires, 19.5 and larger the following is correct: Michelin RV TireGuide: Quote: "If you look at the tire's sidewall, you'll see the maximum load capacity allowed for the size tire and load rating, and the minimum cold air inflation needed to carry the maximum load." From page 6 of the GoodYear RV Tire and Care Guide: Quote: "How much air is enough? The proper air inflation for your tires depends on how much your fully loaded RV or trailer weighs. Look at the sidewall of your RV tire and you’ll see the maximum load capacity for the tire size and load rating, as well as the minimum cold air inflation, needed to carry that maximum load." From the August 2010 Motorhome Magazine "Tread Carefully" tire article: Quote: The maximum load capacity allowed for the size tire and load rating and the minimum cold air inflation needed to carry that maximum load are located on the tire’s sidewall. So if one has not weighed their rig, then the min tire pressure on the sidewall should be used until they have weighed their rig.
38,782 PostsLatest Activity: Sep 10, 2026
