Kayteg1 wrote:
DrewE wrote:
Kayteg1 wrote:
Beside lower ride comfort, what is wrong with inflating the tire to max sidewall pressure?
When was the last time you have seen semi-truck drivers dropping the tire pressure after dropping off the load?
Overinflation causes reduced traction, which can mean compromised handling in an emergency situation.
Do you have a real test to confirm this theory?
Edit. Found test done by Edmunds.
actually improves handling because it provides more "bite"
That test found nothing of the sort; in fact, they didn't actually test overinflating the tires at all, so far as I could tell. It merely found an expert who claimed that a slight overinflation improved handling slightly but compromised braking slightly. Perhaps the expert was correct, at least for some classes of vehicles or some recommend inflation pressures, and perhaps the expert was mistaken (or overgeneralizing)—I do not know. Nowhere did this expert recommend a substantial overinflation.
I remember seeing some informal but reasonably scientific tests performed by a car enthusiast at a skid pad with various tire pressures, and found that for their car the manufacturer recommended pressures provided the greatest lateral grip. I cannot now find exactly where I saw that. However, it would be a fairly simple test to replicate if one were so inclined. (I don't really recommend taking a class A motorhome for trials around a skid pad, though.)
On Ford-based class C motorhomes, at least, overinflating particularly the front tires can lead to quite squirrelly handling, and reducing the pressure to the correct value for the weight often greatly improves that. This is not exactly a traction-related issue, since the handling problems are not due to losing traction, but it is a control and safety issue. (It's also somewhat exacerbated by the somewhat basic and unrefined front suspension design of the Ford E-series chassis.)
