ljr869's avatar
ljr869
The dreaded code 36
Onan Marquis Gold 5500 runs for 3 to 10 minutes then surges and dies. Code 36 means it shut down without being told to. Plenty of clean fuel, just changed fuel filter, pump primes, clean air filter, proper oil level. I'm guessing it's carburetor related seeing as it occurs once it gets to operating temp. That's a bit above my expertise so into the shop it goes.
  • Same thing happened to my 2007....replacing the fuel pump did the trick.
    Good Luck!
  • My generator would shut down. Then when cool run again normal. Fuel pump was shuting down when hot. Replaced fuel pump solved the problem. Apparently a problem because of where fuel pump is mounted.
  • If it has a radiator did you replace the coolant? If so, could be air in the system letting it get hot. Just a thought.
