Mike M2 wrote:
Well this might be old news, but I can't change mine on the rear.
Last month I ordered and replaced the front links from Hellwig to the inner hole and all was fine. I didn't have time until today to tackle the rear and after looking at all the info I thought I could get away with using the stock links on the back. After removing the bolts I notice the sway bar hits the rear end jackpot before I can put them back at the inner hole. Looks like I need to order another set of links to make this work. I don't recall anyone having this problem in the back.
FYI, my sway bar is under the rear not over.
Can you give me the part numbers of the links you used, I think I'm going order new ones for mine.
Thanks
