learningacrossameric wrote:
Well here is the update. The heater shorted out causing the 5amp use to pop. The heater shorted because I have electrical problem with my converter. (I brought out a mobile RV guy after I popped the second 5amp fuse.) The refrigerator is as vintage as my RV and I knew it was going to need replacing or some serious maintenance. I am now thinking about just yanking it out and replacing it with a residential fridge. I will do very little if any boonedocking so running on batteries is not a concern of mine. Looking for opinions on this subject and any red flags that I need to be aware of. I know about the size limitations as far as getting it inside. Has anyone done this and if so do you like it?
Did he replace the shorted out heater and does it now work on electric? If not replacing the heater is about $30.
