The_Texan
Jan 20, 2014Explorer
The Good News Bus
What an awesome conversion. To bad regular coach builders can't build such a coach, without charging a Million $$ for the same quality.
The Good News Bus
The Good News Bus
ferndaleflyer wrote:
Bigdogger is probably president of the HOA. Never had an inspection like that at any RV park yet.......Some of you need to loosen up some. Sound like a bunch of old busy bodies with nothing to do but criticize others without ever considering the skills that it took to do something like that. Do you really think someone would do all that and not consider safety????? I suppose that just because it has a sticker on it that means its safe? Ever seen or heard of a RV with that sticker beside the road burning? Maybe he can get a fire extinguisher from the Good News bus without that sticker.LOL!
deandec wrote:qtla9111 wrote:
didn't get charged 300K for a bus with furniture.
:B :C
artguys wrote:
Jarlaxle...those are most definitely not 11X22.5s...if you look closer you'll see the cast iron spoked hub, which in turn would be attached to the steering knuckle which in turn would be attached to a kingpin and straight axle...The rim is a 20" Dayton style single lock ring rim...and having been in that industry for enough time to know that the tires used in that config were 20" either a 9.00 or 10.00 tube type.
To the best of what I remember, to convert, a different knuckle would be required. And for that reason probably better to find a used axle assembly at a truck salvage dealer.
Driving the bus with those tires could be a very large problem.
artguys wrote:
Interesting they chose to keep the OE 900 or 1000x 20 tube type tires and rims...note; tube type tires and rims not able to convert without changing the entire axle assemblies.
smlranger wrote:
My first thought was how heavy it would be when they are done. I also think leaving so many windows (single pane I would think) will make it less than desirable in cold weather.
Anyway, I can see a time when I was much younger where I might have thought it was a cool party bus. We age, our tastes change, etc.
