Bordercollie
Jul 04, 2013Explorer
Something in the circuit may be dragging your 12 volt DC power down so that turning on the light reduces power to the thermostat, or the house battery may be near dead as mentioned above.Check voltage at the battery, should be over 13 volts if converter is charging it. You may need to clean battery terminals, check electrolyte levels, add distilled water if needed to cover the plates in battery.
38,769 PostsLatest Activity: Mar 28, 2026
